Clutch handle trouble
Old Apr 5, 2010 | 05:41 PM
silvernorange1993zx7's Avatar
Default Clutch handle trouble
ok so i'm new to this whole motorcycle thing. only been riding 3 months and this is my first bike. 1993 zx7r. problem i'm having is sometimes the clutch handle sticks and if i touch it just a little bit it will click into gear. i don't believe it to be a clutch problem. i'm guessing its just in the handle. suggestions? i don't even know where to start!
Old Apr 5, 2010 | 08:54 PM
first suggestion is a shop manual for it. check your cable adjustment and lube or master cylndar oil level if hydraulic. welcome to KF
Old Apr 5, 2010 | 10:49 PM
Prom's Avatar
+1 Lube the cable and invest in a manual. With an older bike it will save you more headaches than you can imagine.
Old Apr 6, 2010 | 06:11 PM
ok yea i got the book....i just asked cause i was wondering if it was a common problem or not. the bike is my only form of transportation at the current moment so i just wanted to get a half idea what i was getting myself into before i start ripping it apart. Thanks for the tips!!
Old Apr 6, 2010 | 07:41 PM
This ride uses a hydraulic clutch. Check fluid levels, or a sticking slave or master cylinder. A good flushing and good oil replacement is recommended. Good luck
Old Apr 13, 2010 | 03:31 PM
pretty sure its in the slave cylinder. i'm getting a rebuild kit for like 35 bucks with shipping and all. so hopefully that does the trick. thanks again...
Old Apr 14, 2010 | 02:14 AM
Prom's Avatar
sweet, good luck on the fix, and post up some pics
Old Apr 15, 2010 | 05:15 PM
runovryou's Avatar
Came across this while reading yesterday.. not sure it can help you out or not. Sounds similar to your problem though:
Clutch back torque limiter springs: These can be a weak point (and should be checked fairly regularly A.M.). They can break into many pieces hopefully staying within the clutch basket and if one of the pieces lands right, you may not be able to disengage the clutch. If this happens on the road you may be stranded.
Try engaging and disengaging the clutch to dislodge the broken piece and get home ASAP!
From this website: http://homepage.ntlworld.com/webzxr/...es/useful.html
Old Apr 16, 2010 | 03:55 PM
yea that sounds just like it. thanks
Old Apr 16, 2010 | 09:06 PM
Good info runovryou, I did not think that it was a big issue until I read that link.
