ZX6R - hard to start
Old Jun 11, 2008 | 10:24 PM
ylwf3vr's Avatar
Default ZX6R - hard to start
Just got my bike out of the shop. Got full 30K tune up and few repairs. I've found out that it has full Akroapovic(?) exhaust system and "jetted" for that pipe. What does the "jetted" mean?
Also, due to the exhaust/pipe being jetted, I have hard time starting it. The guy started it right away, but whenever I tried to start it it just turns and turns but no start. He said leave the choke closed since it's closed unless it's cold out. Any ideas on why it doesn't want to start? And any help/suggestions? Thanks
Old Jun 15, 2008 | 05:59 PM
ylwf3vr's Avatar
Default RE: ZX6R - hard to start
update: seems like it starts eaiser if the kickstand is up.... ???
Old Jun 15, 2008 | 08:04 PM
s197richie's Avatar
I know on my bike, when I'm low on fuel, it starts more easily if I get on the bike and hold it upright (normally I just start it on the kickstand)...I guess the fuel flows from the tank more easily when the bike is straight up and down? IDK.
I also know that my next bike will be the new generation ZX6R; fuel injection and a gear indicator ftw.
Old Jun 16, 2008 | 12:41 AM
ylwf3vr's Avatar
ORIGINAL: s197richie
yessir same here lol
Old Jun 16, 2008 | 01:04 AM
joe sprocket's Avatar
i LOVE my 07, the gear indicator is awesome, she handles AMAZING and the fuel injection makes for easier starts and warm ups. but i also have a 98 zx6r and i use the choke all the time. unless i have been riding it in the last couple of hours.
Old Jun 16, 2008 | 02:03 AM
KawiNinja07's Avatar
ORIGINAL: ylwf3vr
Jetted means the carburators were fitted with the appropriate jets for that exhaust system, so that the fuel air mixture would be correct. The reason people do this is because most bikes come lean from the factory and adding an exhaust system usually makes it more lean.
Old Jun 21, 2008 | 09:41 PM
ylwf3vr's Avatar
will the bike being that lean cause it hard to start? if so, I guess it's not jetted..
Old Jun 21, 2008 | 09:42 PM
ylwf3vr's Avatar
i just changed the spark plug to NGK ones hoping it will do the trick but it's still the same.. backfired and then started.. turned it off and tried to start it and still nothing.. any thoughts?
Old Jun 26, 2008 | 02:30 AM
speedracer138's Avatar
What did the plugs look like? Were the porcelain (White part) white, brown or black? That will tell you if it's running rich or not. Also check your air filter. My supervisor has a mouse nest (really) in his air box. Make sure the air filter is clean. Drain your carbiretor float bowls (drain screw at the bottom of each bowl). Add some RXP in the tank just incase your fuel isn't that good or has water in it.
cegusman
Sep 25, 2012 02:08 PM
IQOUTLAW
Mar 23, 2010 02:33 PM
schnebelen
Aug 25, 2006 09:52 PM
ldakotadl
Jul 12, 2005 08:33 PM
