Went Canyon carving
Old Aug 13, 2007 | 04:09 AM
OMalley912's Avatar
Default RE: Went Canyon carving
Just the ignition cover. The previous owner fell over in the driveway and scaped a few things that are barely noticeable. It's only 94.00 but it can wait till winter for a little overhaul. Not sure if I'll get rear sets might not be comfy for the street.
Old Aug 13, 2007 | 05:24 AM
Ninja81's Avatar
I dont know if the rear sets are really needed for me. I dont know. I think I dragged the shift lever around because I was not wearing pucks. I think with the pucks, I will have more than enough clearance to use the stock ones. Im just glad I didnt loose the rear tire.
Old Aug 13, 2007 | 06:33 PM
speedracer138's Avatar
If you tr to straighten it, the lever will break. Aluminum will bend one way once and will break/ snap if you try to bend it back. It work hardens unless it's really soft. Once you get a replacement, you can try to straighten it. I have seen a nice set of adjstablerearsets for $230 on ebay.
Old Aug 13, 2007 | 09:28 PM
alleakhatt636's Avatar
the only way you will straighten that is to put heat on it. but its a P.I.T.A......
Old Aug 14, 2007 | 05:59 AM
Nunlowr's Avatar
its called anealing (sp) you have to heat it then cool it to get rid of the work harding that happened when it hit. I dont even know it that will work because it is a cast aluminumbecauseit is different then sheet.
trev0006
Mar 4, 2009 06:26 AM
tylercq
Jan 9, 2009 01:32 AM
Ninja81
Aug 10, 2007 06:11 AM
speedracer138
Apr 23, 2007 08:49 AM
Knivez
Sep 23, 2006 06:17 PM
