Transmission Problelms
Old Jul 20, 2007 | 07:33 AM
evil636's Avatar
Knee Dragging Pimp
Default RE: Transmission Problelms
read skg's problem, that will start to happen to you next
https://www.kawasakiforums.com/m_156399/tm.htm
Old Jul 20, 2007 | 07:37 AM
evil636's Avatar
Knee Dragging Pimp
is your cable good ? no pulling or binding when turned a certain way ?
Old Jul 20, 2007 | 12:20 PM
Kohburn's Avatar
ORIGINAL: Baby Ninja
Well, at first it was doing it mostly when I'm leaned to the left and accelerating hard. Lately though, it has been doing it on both sides and sometimes even when upright. Around town it has been okay. It's just when I start to head to the twisties and local backroads and riding hard. Could it also be that my 2nd and 3rd gear are going out. I have not yet encounter doing it on the 4th or higher gears?
the gear teeth themselves are most likely completely fine. but the engagement dogs are part of the gear (on the side) they will start to wear down and become angled. once that happens the hard acceleration and side loading will make them pop out of gear. sometimes it will recatch but as they get worse it will become nearly impossibly to keep it in gear. (they work the same in car race trannies that use dogs instead of synchros)
from what i've read about kawasaki's it can be caused by the shift forks and shift drum wear down and not fully engaging the gear dogs. but once its gone on long enough to progress to the point you describe the gear dogs would at the very least need to machined flat again if not replacing the whole gear.
i just picked up a replacement set of shift forks and shift drum on ebay. i'm going to work on cryo treating the shift drum and add a thin layer of material to the wear surface of the shift forks with a much higher hardness than stock (along the lines of tungsten carbide). that way if I ever have to swap the parts in i'll have a superior set that won't wear out for a long long time.
cantcme
Oct 31, 2006 07:01 AM
bryantjt
May 15, 2006 02:00 AM
Backpacker1002003
Jan 7, 2006 09:38 AM
roboticninja9r
Ninja ZX-9R
Sep 15, 2005 04:39 AM
jkarner
Ninja ZX-9R
Sep 9, 2005 06:05 AM
