Transmission Noise
Old May 27, 2008 | 09:19 PM
Wrecks30's Avatar
Default Transmission Noise
Sup? I am a new member here, I have an 07 ZX6 and LOVE IT. but anyway, the bike only has around 400 miles on it, but i went riding with a friend through the Mountains here and put the bike through some pretty intense curvage. but never really killed the RPMS. Now coming home on the highway i noticed a noise when I would let off the throttle, not pinging or metal on metal but more like something skipping, no loss of power or anything like that. Sorry if i didnt explain very well, but Thats all i can really say. anyone know what the sound may be? Thanks in advance
Old May 27, 2008 | 09:27 PM
kazerotor's Avatar
Default RE: Transmission Noise
so you haven't broken in the bike? what rpm are you riding at?
Old May 27, 2008 | 10:08 PM
Wrecks30's Avatar
Mostly 4 to 5k, maybe6 to 7here and there, but not constant, just coming out of curvesI know its a little more than supposed to be.
Old May 28, 2008 | 01:33 AM
speedracer138's Avatar
You could be hearing popping in the exhaust from downshifting (Lean misfire). You can do the KLEEN Air mod later. It also could be your slipper clutch releasing if you're downshifting and shutting off the throttle hard but I don't think it's that. Also, Change your oil; it's time.
Old Jun 17, 2008 | 06:08 AM
Flush's Avatar
Let's keep it simple here. new bike. probably nothing wrong. Did you check your chain? the initial stretch is substantial. Especially if it's the O/E P.O.S.
Old Jun 17, 2008 | 01:48 PM
GS247's Avatar
ORIGINAL: Flush
+1 i was thinking chain tension
Old Jun 17, 2008 | 02:03 PM
+ eleventy billon. and welcome to KF guys!
ORIGINAL: Flush
Old Jun 18, 2008 | 03:31 AM
Yes, good idea; check the chain and if it stil does it, may be it's the popping on deceleration. These bikes do that a lot.
Old Jun 18, 2008 | 10:15 AM
Wrecks30's Avatar
Thank you guys, and yes it was the chain, I tightened it and she is as good as new.
Thanks Again!
Old Jun 18, 2008 | 01:43 PM
Wow! Must have been pretty Loose to be skipping! And with only 400 miles? They must not have adjusted it correctly during the bike setup. Great you figured it out. See, sometimes it's just that simple.
