Trackday/ Racebike build-up 05 636
Update? What update? With all the cars breaking down, I haven't had any chance to work on the bike yet. Hopefully I'll be able to start her up tomorrow or on Turkey Day!
Good stuff speed racer the best of luck with youre project! Thanks on the smog info I found a vaccum leak and a vaccum pinched, bike runs like a raped ape now man! Routed crankcase fumes to a tee on the valve cover, found you can do it this way or block off the valve cover and vent crankcase to atmosphere thruogh a small filter..... the Attack race team spilled the beans![8D]
I got the bike started and running but the FI light is on. I don't have the radiator installed so the coolant temp sensor may have something to do with that. It runs smooth though. I just need a bunch of hardware & bracketsto finish it.
The front brakes are on with Galfer Steel braided superbike lines and cross drilled banjo bolt ready for bleeding. Gonna usr Motul RF600 (600 degree boiling point) brake fluid.
Nope, not yet. Maybe it's the water temp sensor or something not hooked up yet. The radiator still isn'tinstalled yet.If not then I'll have to get one of you 05-06 experts to help me out. I just found pretty much all the harware and brackets I need so hopefully I'll get it done bythis weekend. Might have to sell this one and build another.
