tire specs for 05 636 ?????????
well i was reading the service manual and came across this. I find it hard to believe that our tires are only rated for 80mph.
Tires
Air Pressure (when Cold):
Front Up to 180 kg (396 lb) load: 250 kPa
(2.5 kgf/cm², 36 psi)
Rear Up to 180 kg (396 lb) load: 290 kPa
(2.9 kgf/cm², 41 psi)
Tread Depth:
Front 3.6 mm (0.14 in.) 1 mm (0.04 in.)
(AT, CH, DE) 1.6 mm (0.06 in.)
Rear 5.8 mm (0.23 in.) Up to 130 km/h (80 mph):
2 mm (0.08 in.)
Over 130 km/h (80 mph):
3 mm (0.12 in.)
Standard Tires: Make, Type Size
Front BRIDGESTONE, BATTLAX BT014F
RADIAL J
120/65 ZR17 M/C (56 W)
Rear BRIDGESTONE, BATTLAX BT014R
RADIAL J
180/55 ZR17 M/C (73 W)
Tires
Tread Depth:
2 mm (0.08 in.)
3 mm (0.12 in.)
RADIAL J
RADIAL J
well duh... think about it...2 tires 80mph each... that's 160 mph... We are golden, esp those of us with th-1/+2 who top out at 155
I know the logic doesn't work, but worth a chuckle
I can't believe you read the manual
Did you read the part that states you should not down shift until you are under 5000 rpms in fear of rear wheel lockup? What was the purpose of going with the slipper clutch?
Anyway, the ZR tires are rated at over 149 mph if that makes you feel at ease at that speed
Mike
Did you read the part that states you should not down shift until you are under 5000 rpms in fear of rear wheel lockup? What was the purpose of going with the slipper clutch? Anyway, the ZR tires are rated at over 149 mph if that makes you feel at ease at that speed
Mike
