Sprocket change
Old Jul 31, 2006 | 11:41 PM
txredneckmedic's Avatar
Default Sprocket change
Well I did a -1 on the front...and you can definetly feel the difference. soon gonna do +2 or 3 in the back and a new chain
Old Aug 1, 2006 | 12:16 AM
BigO's Avatar
Default RE: Sprocket change
Is that more torque or top end that you noticed the difference?
Old Aug 1, 2006 | 12:20 AM
more torque....its like adding 2 or 3 in the back
Old Aug 1, 2006 | 12:35 AM
BigO's Avatar
Sounds Thrilling. I think 160 on my 04 636 is fast enough for me so I won't change to much. although wheelies will be a bit easier with more torque.
Old Aug 1, 2006 | 12:44 AM
well more torque = less speed
Old Aug 1, 2006 | 12:48 AM
BigO's Avatar
True so I should have put it this way. I will not decrease any tourqe on my bike to make it go faster. If I want to do more wheelies then I might change the sprocket to gice it more tourqe and then less top end speed.
Old Aug 1, 2006 | 12:58 AM
Notstock's Avatar
I run -1 +2 and it rocks. Screw the top end, for me I do not do much ridding at 185 so it is better to be quicker. Since then I have seen 156 on my speedo, and it is correct, and there was still more left, I bet she will top out at 170.
Let us know what you think about -1+3 tx.
Old Aug 1, 2006 | 01:32 AM
evil636's Avatar
Knee Dragging Pimp
stick with the -1+2 tx. even though 1 tooth in the rear wont make a whole hell of a big difference. i think most of the power up kits use a 45 rear anyway. post back.
Old Aug 1, 2006 | 05:05 AM
speedracer138's Avatar
With that gearing change, the speedo will be closer to being accurate I bet; because the engine will turn faster but the bike will go slower top speed. The speed sensor is located at the front sprocket shaft.
Old Aug 1, 2006 | 05:26 AM
Notstock's Avatar
I believe that is the odometer and not the speedo. The speedo is electronic on on the zx6 636 and the 10.
Sproket change will through the speedo off a lot.
http://speedohealer.com/eng/intro.htm depending on the year of your bike, 04 and earlier are plug and play and 05-06 are wire it in. Either way it is a breeze, corrects your speedo and makes it accurate.
