some ? about dampers
Old Mar 17, 2007 | 10:58 PM
skelly6458's Avatar
Default some ? about dampers
so what are the major diffrences between GPR/Scotts style (rotary?) vs Ohlins style (linear?)? I tried searching but only one post about dampers came up. I just looking for some I can use to make a decision on what one im gonna pick up
thanks
Old Mar 18, 2007 | 01:16 AM
KevyzToy's Avatar
Default RE: some ? about dampers
I'm not sure, but I don't think the Ohlins is adjustable. The Scotts / GPR is. I would go the Scotts route myself. I like adjustablility.
Old Mar 18, 2007 | 02:30 AM
Unreal's Avatar
I put a scotts on my 06 zx6r last week. So far I like it a lot.
Old Mar 18, 2007 | 06:25 AM
speedracer138's Avatar
The Ohlins, Hyperpro & most linear dampers dohave adjustments unless they are the stock ones (except the ZX10R which is an Ohlins). The Scotts is made by Ohlins also. They are all good; just depends on your taste. They perform the same function regardless of what one manufacturer say theirs does better. If it's mounted on the upper steering stem and the frame, it works on the same forces the same way. The ones that are for the ZX6RR (mounted on the LH side of the frame & attached to the fork)work a little different but achieve the same result.
Old Mar 18, 2007 | 03:58 PM
xmxracer's Avatar
DOES ANYONE KNOW THE COST OF EACH ONE.
Old Mar 18, 2007 | 06:19 PM
Unreal's Avatar
I paid $380 for my scotts.
Old Mar 18, 2007 | 06:34 PM
skelly6458's Avatar
from looking around the seem to all be between 350 and 450. i think ill just go with scotts or gpr depending on which one i get a better deal on when i get the funds anyone know if a new GB can be set up
Old Mar 18, 2007 | 11:26 PM
Check with Evil636; he has 2 Hyperpro dampers for sale. Here's a picture of mine.
[IMG]local://upfiles/1485/B20A85AFDB424605A4C9D16F0C233980.jpg[/IMG]
Old Mar 19, 2007 | 12:10 AM
skelly6458's Avatar
o yeah thanks. was it hard to make that carbon fiber cover?
Old Mar 19, 2007 | 07:23 AM
Not really because I bought one of the CHEAP Carbon look trim pad on ebay and used it as a template. I had to split the CF pad at the sharp bend down but it came out OK. Here's a better picture. Oh and another pic of the damper too.
[IMG]local://upfiles/1485/C18F30415F224501A89674247B2BE89A.jpg[/IMG]
