Shift Light..
Old Oct 1, 2007 | 10:23 PM
nin.zx.6r's Avatar
Default Shift Light..
hey guys. i was looking through my ownders manual and it said to not use the shift light for regular driving and for competition only...i have an 06. does it dmg the bike in any way or does it just state that for safety reason?
Old Oct 1, 2007 | 10:33 PM
NiteQwill's Avatar
Default RE: Shift Light..
No, it does not damage the bike.
It's for safety reasons. Granted, I think it's SAFER to have a shift light b/c you know where your optimal shift points may lie.
Old Oct 1, 2007 | 10:46 PM
Ybslow's Avatar
ORIGINAL: NiteQwill
True, but remember you have a rev limiter, and the optimal shift point will vary depending on gearing, type of riding, mappingetc. Once you find the sweet spot in the RPM's you'll know when to shift without the light.I don't know anyone that usesit (maybe dragsters). Also it IS adustable so you can have it come on when ever you like, it's probably set from the factory at some obscure RPM.
Example,my 636 turns 109 (max)horses at 13.5. Thats with 1:2 gearing and akropovic slip on (pre PC mind you), don't need the light for that, 13.5 sounds prettydistinctive LOL. Anyway, you won't damage the bike by not shifting at the shift light, it's only a suggestion.
Old Oct 1, 2007 | 10:49 PM
Ybslow's Avatar
PS keep in mind, when shifting by sound as most people do, helmet, earplugs etc, will get you used to the sound of your bike. Changing one of these may alter the sound and therefore alter your shift points. Happens to me everytime I forget my earplugs at the track.
Old Oct 1, 2007 | 11:13 PM
nin.zx.6r's Avatar
alright cool guys. thanks for the info!
Old Oct 2, 2007 | 12:29 AM
mikedrinfla's Avatar
The factory setting for your shift light ig 12500 RPM's. You can manually adjust your shift light to come on at a different RPM between 12000- 15500. If I remember correctly. I have my shift light so it comes on at 13500 RPM's my point of highest HP. In the owners manual it will tell you how to adjust it. I think it is... Turn the ignition on press and hold down both buttns on the cluster and then adjust the range the same way you do your clock. I fyou need help I can look it up. But aas I stated it is in your manual.
Old Oct 2, 2007 | 07:11 AM
rocketrotary's Avatar
Does anybody know if the '07+ has that as well?
Old Oct 2, 2007 | 11:13 AM
Ybslow's Avatar
don't see why not.
Old Oct 2, 2007 | 03:05 PM
sure doesive never seen it go on yet tho, im a poontang[&:]
ORIGINAL: rocketrotary
Old Oct 3, 2007 | 01:50 AM
Ok poontang, how does the gear indicator work for ya? Is it any good?
