See through tail after fender eliminator install
Old Jul 10, 2008 | 12:53 PM
KawiZX6R2006's Avatar
Default See through tail after fender eliminator install
Well I finally got rid of the black plastic mess that is the rear fender on my 06 636. One issue, once all that plastic goes away you can see right to the ground with the rear seat off. Not only did I have virtually no storage before taking it out, now I can't put anything back there since it will just fall out. Is this just something I need to live with? Thanks.
Old Jul 10, 2008 | 02:52 PM
Default RE: See through tail after fender eliminator install
[sm=ttiwwp.gif]
Old Jul 10, 2008 | 09:52 PM
This is what I am talking about.
Old Jul 11, 2008 | 02:02 AM
mikedrinfla's Avatar
Ok this is what you have to do. you have to take the blinkes and re install them. Then outline where the rear fairing and the plastic touch. Take a peice of white chalk and out line it. Then take the blinker assembly off and cut along the chaulk line. Re install and wha la no more see thourgh tail. Hope this helps. I did it to mine took about a 1/2 hour. I left the tail section on. If you take off the tail section might take a little longer.
Old Jul 11, 2008 | 12:05 PM
Thanks for the advice. Do you have any pictures of the outcome? Thanks.
dlat88
Apr 14, 2010 04:27 PM
mvandeusen600
Jan 10, 2009 10:26 PM
Grimwell
May 11, 2008 06:12 AM
rocketrotary
Nov 4, 2007 01:47 PM
creese
Jul 18, 2005 07:00 PM
