riding bike on 3 cylinders
Old Oct 14, 2007 | 07:35 AM
anthz's Avatar
Default riding bike on 3 cylinders
Hi I have a 2005 zx636, whilst riding the bike this morning one of the connections for the pc3 came loose, and my bike quickly ran on 3 cylinders. I wasn't able to get home to get it fixed and rode the bike a further 40 miles. I was giving it some stick and I am a little worried as to whether I did any damage to the bike whilst riding on 3 cylinders. I have now fixed the loose connection and the bike runs fine on all 4 cylinders.
Were there any negative effects by riding on 3 cylinders for an extended period of time? Please voice your inputs..
Old Oct 14, 2007 | 09:28 PM
Default RE: riding bike on 3 cylinders
Why give a sick engine stick for 40 miles? Guess that you were not too worried then. Congrats on it running fine for ya now. I would still check the plugs. Although they may have cleaned up now.
Old Oct 14, 2007 | 10:57 PM
anthz's Avatar
I was giving it some stick because I initially thought that it was a bad spark plug. I was trying to clean it..
Is it possible for the unburntgasoline in cylinder #4 to pass through the piston rings and into the oil?
This is my main worry.
Old Oct 15, 2007 | 12:44 AM
meanstrk's Avatar
No worries. Any fuel would just get sucked out the exhaust valve anyways. You are not gonna hurt it by riding on a deal cylinder like that, so don't sweat it.
Old Oct 15, 2007 | 01:12 AM
05ZX6R's Avatar
The pistons rings will not allow any unburnt gas to pass by them, just like when the engine is running normally. The unburnt air/fuel mixture will just get compressed and shoved out the exhaust where it would be ignited in the muffler making for a little backfiring.
Now you said the PC3 connection came off and this is an 05 636, so I assume it was not controlling the fuel injection nozzle and not even spitting fuel into the throttle body anyways. I bet the engine was running pretty cool for that 40 miles also.
I wouldn't worry about it, newer vehicles like the 2006+ Ram HEMI will shut off fuel to 4 cylinders making it a 4 cylinder engine whenever you are at less than 50% throttle. The only difference being that the crankshafts are still counterbalanced.
Old Oct 15, 2007 | 01:33 AM
kozumasbullitt's Avatar
no negative done there, dont worry about it.
Old Oct 15, 2007 | 03:00 AM
Mott Power's Avatar
if your worried about it getting into the oil then just simply do an oil change, problem solved-o!
Old Oct 19, 2007 | 12:03 AM
nin.zx.6r's Avatar
how can u tell if you're riding on 3 cylinders?
Old Oct 19, 2007 | 01:00 AM
Ybslow's Avatar
ORIGINAL: nin.zx.6r
It says "Triumph" on the side of your gas tank.
Old Oct 19, 2007 | 01:14 AM
05ZX6R's Avatar
ORIGINAL: Ybslow
ORIGINAL: nin.zx.6r
Now that's funny! 675cc FTW
EyeballBoy
May 7, 2008 10:58 AM
b_joannblue
Dec 20, 2007 12:36 PM
markturbo
Feb 10, 2007 09:14 AM
shon
Mar 30, 2006 09:05 PM
shankers
Dec 13, 2005 10:55 PM
