rev limiter q
Old Apr 21, 2006 | 01:59 AM
murphmaster5's Avatar
Default rev limiter q
just wondering if hitting the rev limiter every now and then is that bad for the bike, i like to do smokey burnouts and i kinda get a little out of hand and bounce off it a couple time.
Old Apr 21, 2006 | 02:11 AM
speedracer138's Avatar
Default RE: rev limiter q
I wouldn't do it all the time especially during burn-outs. Less resistance on the engine to over-rev. That is what it's designed for; to shut of ignition so the motor doesn't over-rev to destruction. You never want to rev your bike to redline in neutral because the motor will spin-up too fast; no resistance. You could throw a rod through the case and/ or bend valves if you did that. Past redline you lose power anyway because that's when the valves start to float as you can see on the Dyno run graphs.
Old Apr 21, 2006 | 02:55 AM
MAD KAW's Avatar
i would say question answered
Old Apr 21, 2006 | 05:08 AM
thank you
Kacey Castle
KX250 & KX250F
Jan 28, 2020 08:46 AM
CravingPantera
Jan 26, 2013 12:53 PM
oldfart_newrider
Nov 1, 2011 03:57 AM
OMalley912
Feb 4, 2008 10:46 PM
markmeinteil
Ninja 250R
Aug 9, 2006 12:56 AM
