RESETING ECU??
Old Oct 10, 2007 | 09:38 PM
intense_05_636's Avatar
Default RESETING ECU??
i'm tryin to clear ne codes on my bike becuzmy FI light is on.They said i can just reset my ecu to do this, but im not sure if im doin nething wrong.I disconnected both battery terminals and then waited 15 mins and then hooked it up but the damn FI light is still on. I'm i doing something wrong is this how u even do it? thank for yalls help
Old Oct 10, 2007 | 09:54 PM
Ratkiller's Avatar
Default RE: RESETING ECU??
Why is your FI light on? Did you do something with the exhaust or injectors?
Old Oct 10, 2007 | 10:31 PM
fi light is on becuz of the exhaust. i install and servo fix on the other day and its still on
Old Oct 10, 2007 | 10:37 PM
Ratkiller's Avatar
Double check your install of the servo fix. If possible post pictures. Thats what a servo fix does, it's tricks the servo so the FI light will trun off. You should not have to reset.
Old Oct 11, 2007 | 12:20 AM
here is a pic of the servo fix
https://www.kawasakiforums.com/upfil...4419BB3C57.jpg
Old Oct 11, 2007 | 03:10 PM
Ratkiller's Avatar
Looks good to me. Here's a link on how to install the servo fix. https://www.kawasakiforums.com/m_48464/tm.htmJust in case. If that dosen't work I don't know what to tell you, but back to your original post I know there is some remaining power left in the electrical system even after you unplug the battery. But waiting 15 minutes should taken care of done that. Try leaving your headlights that should do it.
Old Dec 17, 2007 | 02:48 AM
speedracer138's Avatar
I had the same problem and found that the actuator cam was designed wrong. It was clocked way off! As soon as I installed the stock cables etc, the light went out. I'll get the correct one or make my own. I have marked the stock rotor to show the stopping points on the servo. If you rig someting up to make it stop at those 2 spots,the light will stay off. The marks on the rotor line p with the mark in the center between he 2 cables (difficult to see). I'll post another pic and the fix as soon as I ge around to it.
[IMG]local://upfiles/1485/E29E7C73FDDD40F5A09B5E5C60B20CA7.jpg[/IMG]
Old Dec 17, 2007 | 03:03 AM
To reset the ECU, you have to get into the dealer mode 2 and it's best to have the manual to do it. Unless someone (05 ZX6R) can post that page up. It says (for Dealer Mode 1)to ground the Orange diagnostic lead for more that 2 seconds then keep it grounded and read the FI light flashes. To get to Dealer Mode 2, you have to groud the lead, then remove & ground aginat least 5 times within 2 seconds! Yikes! That will be hard to do but I have a way around it. Use a strip of tape on the seat bracket and cut 6 small slots in the tape and remove it. Now all you have to do is ground it and run it across the tape. It wil make & break the groundat least 5 tmes and you can get in Mode 2. To clear the codes, pull in the clutch for more that 2 seconds while it is still grounded. Here's a pic of the tape on the bracket. I used masking tape.
[IMG]local://upfiles/1485/CA401AC01D394D52B95007CA9519CA1A.jpg[/IMG]
Old Dec 17, 2007 | 10:37 PM
05ZX6R's Avatar
Old Dec 18, 2007 | 12:51 PM
Damn! You are GOOD & FAST!! THANKS!
