Rear lic. plate light location??
Old May 1, 2007 | 11:46 PM
scottay321go's Avatar
Default RE: Rear lic. plate light location??
Actually, those bolt lights wouldn't work for my set-up.(wires) Wonder if anyone makes battery powered ones that you can just turn on when you need to.
Old May 2, 2007 | 03:53 PM
jds636's Avatar
they will work...you just have to run the wire under the tail fairing, the down the back side of the frame and behind the swing arm...it will work
Old May 2, 2007 | 04:16 PM
hicktown's Avatar
i didnt realize you need a light on the plate. arent the headlights of a pig bright enough?
Old May 2, 2007 | 05:30 PM
ORIGINAL: jds636
Thanks.....do I just tape the wires to the frame and the backside of the swingarm? Don't want it to looktoo ghetto...hehe.
Old May 2, 2007 | 09:29 PM
jds636's Avatar
you can hide much of it under the tail section then run it behind the frame and swing arm...if you have a black frame, just find black wires and use eletrical tape with a quick swoop around the swing arm, wont be able to notice it really unless you look. me personally im not too worried about how it looks, just as long as it works, you may be more picky than i am. I had mine for a while ziptied up behind the wheel to the rear foot pegs, and had the wire run down inside the tail section then pop out, didnt look professional, but that was about my only option.
Old May 3, 2007 | 02:16 AM
Thanks jds636.....one other thing, how exactly do I wire this thing up? Never messed with any of the wiring at all. Does anybody have a diagram or something for this? Sorry so clueless....hehe. Thanks again.
Old May 3, 2007 | 05:37 AM
speedracer138's Avatar
Run the wires from your stock lic plate light connector. Cover/ route the wires through some black heat shrink and run it along the frame & swingarm like jds636 said. you can use some clear RTV as adhesive to secure the wires every few inches. Route it underneath the swingarm & behind the frame.
ol'klx-er
Jan 29, 2014 06:28 PM
olderthandirt
Jan 10, 2009 01:14 PM
kronus
Jun 27, 2008 01:27 AM
Shrumple
May 30, 2007 02:20 AM
Scott V
Nov 8, 2006 04:41 AM
