question about seafom
Old Jul 12, 2008 | 04:44 AM
768 Ryda's Avatar
Default question about seafom
hey guys can u add seafom to a bikes oil with out causing clutch slippage or any other internal engine damage, i read the bottle and it says u can use it in a motorcycle, but is it safe tho, also whats the best way to use it in the bikes oil or gas tank
Old Jul 14, 2008 | 05:11 PM
Kohburn's Avatar
Default RE: question about seafom
i don't believe in adding seafoam to oil unless you are doing it just before draining the old oil
Kohburn's Avatar
seafoam has a lot of solvents in it that thin down oil, imo not good for bearing life. but used before an oil change it can flush out grime buildup.
Old Jul 15, 2008 | 12:02 AM
768 Ryda's Avatar
how long do u guys think it will be safe to run in the oil before oil change
Old Jul 15, 2008 | 02:05 AM
Why would you do this ryda? You forget to change your oil 20,000 miles ago?
Old Jul 15, 2008 | 11:36 AM
768 Ryda's Avatar
ORIGINAL: Dragone#19
no i change my oil reguarly but talked to a guy and he performs maintence reguarly also and he said he noticed a difference with useing this stuff
1stCruiser
Apr 23, 2011 03:27 AM
fastex500
Mar 28, 2008 01:41 AM
BlueDream
Nov 21, 2007 05:35 PM
