Power Commander Necessary?
Old Sep 8, 2006 | 08:08 AM
5thgen's Avatar
Default Power Commander Necessary?
I'm looking to buy a slip-on (either yosh, muzzy, scorpion, or akra) mainly for the sound. Will I lose horsepower if I don't buy a PC along with the pipe?
Thanks
Old Sep 8, 2006 | 01:51 PM
FuryofGreen's Avatar
Default RE: Power Commander Necessary?
they go hand in hand like bread and butter, like toast and jam, like gravy and mashed potatos, like .. ahh fuggit buy the power commander
Old Sep 8, 2006 | 02:17 PM
nemo636's Avatar
I'm not an expert, I've just asked this question a lot. Variances allowed due to a million different models of slip-ons, basically if you put on just a slip on it will not hurt the bike. Alone it will definitely adjust the tone, but you're not getting everything out of it. Another thing to consider is intake as well. Generally when you get the slipon, you pickup a "performance air filter" and a power-commander. High air flow doesn't always mean best results either. Check out what other people who already have that pipe and what kind of gains they got with what equipment. I guess to get back to your actual question, it won't hurt the bike but it's like running a sprint in cement shoes. You can do it, but it's not the best method and you're not going to be at your full potential. Just my opinion[sm=usa.gif]
Old Sep 8, 2006 | 05:38 PM
5thgen's Avatar
Thanks all. I've just found out that Scorpions are designed so that you dont need a PC. I'll probably go with that.
Old Sep 8, 2006 | 07:23 PM
walight01's Avatar
just about any slip onexhaust doesn't "require" a pc III
Old Sep 9, 2006 | 06:51 AM
speedracer138's Avatar
Yes, but a PCIII will benefit your bike in being able to run different maps or a custom map to get the most horsepower out of it. The Slip-Ons provide a much better Air-Flow and especially if you get a K&N or BMC Air filter, you should get a PCIII IMO. You can also use a map to provide you the best powerband for your riding style. The guy that tunes my PCIII Map used aa available MAP that gave the most amount of Mid-range HP & Torque, and just so happened to produce the most top-end HP also. If I had a custom MAP, I could get more power.
Old Sep 9, 2006 | 07:34 AM
Knivez's Avatar
How much would a BMC air filter improve performance and/or the life of the engine? (is it worth the 73 bucks)
Old Sep 9, 2006 | 07:36 AM
uneducatedstudent's Avatar
its not necassery or however you spell it, but i mean is it necessary to have 115 horsepower on your bike, dude OVERKILL, overdoing it is the way to go, i know that i personally have little mans syndrome and have got to go big as i can get hahaha
Old Sep 9, 2006 | 07:44 AM
BMC or K&N will improve the performance but not the life of the engine. The whole reason it flows freer is to allow more air with less restriction, and with more air comes in more dirt/ dust. All the really fine stuff the stock air filter stops will go through the K&N or BMC. You can see light through those. And airflow follows the path of least resistance. As long as you dont mind rebuilding your engine sooner and changing the oil & filter more often than recommended.
Old Sep 9, 2006 | 07:50 AM
Knivez's Avatar
what kind of change in performance will there be?
