oil oil oil
I run full synthetic in mine. Everyone is gonna post a different type of oil to use, including myself. As long as the oil you put in was not energy conserving, then you will be fine. The energy conserving oils can cause clutch problems because of some additives they put in. I myself run Mobil 15w50 full syn.
What kind of oil, what brand and what weight did you use?
since red bull keeps my engine pumping strong, i figure if would help keep my 636 running strong. So I just use 4 quarts of red bull, and since it's release I use Vault as an additive when I fill up the gas tank...
