Oil light help/sprocket change
Old Aug 15, 2007 | 02:28 PM
Sturgell's Avatar
Default Oil light help/sprocket change
I just changed my oil and filter I used a Kawasaki filter and mobil 1 10-30 full synthetic and my oil light will not go off now. I primed the new filter and everything and it is full of oil. Is there something I am missing? I have had bikes take a second or two but not this long. Also replaced the plugs and have the fuel tank setting up and I dont know if that has anything to do with it.
________
vaporgenie vaporizer
Old Aug 15, 2007 | 02:40 PM
Sturgell's Avatar
Default RE: Oil light help
I imagine I need to get some 10-50 but I haven't ever had this happen before on my other bikes. Off to get some different oil I guess. Does anyone know what pressure trips the oil light?
________
R51
Old Aug 15, 2007 | 04:02 PM
aszrael1266's Avatar
The Dude
I know it may sound dumb but did you check the site glass to see if it is at the full level?
Old Aug 15, 2007 | 04:28 PM
Sturgell's Avatar
Yeah it was full I changed the oil to 15-50 but it was still doing it til I hit the throttle a little and then it filled the filter and the light went off.
________
honey oil
Old Aug 15, 2007 | 05:32 PM
sup_uni's Avatar
yeah normally that light only comes on when you have high or low oil pressure, did you check to see if it is overfilled? 4 qts. max?
Old Aug 15, 2007 | 06:00 PM
Sturgell's Avatar
Its fine now. The light went off after a little blip in the throttle. Now I am doing a sprocket swap and that front sprocket is a real BITCH to get off without an impact.
________
volcano digital
Old Aug 15, 2007 | 07:34 PM
The Dude
That happened to me once. The first time I change my oil. After I reved a tad the light was off.
Old Aug 15, 2007 | 10:17 PM
Sturgell's Avatar
This thing is all kinds of different now power wise and I couldn't even get the -1 on the front cause the damn nut was so tight. I think I will like it when I am done though, does a lot better out of the hole.
________
how to make a vaporizer
Old Aug 15, 2007 | 10:52 PM
The Dude
I think there is a coter pin thats bent around with the front nut on the sprocket. I channged mine a while ago.
Old Aug 16, 2007 | 02:36 AM
Sturgell's Avatar
No cotter pin just an awkward angle and red loc-tite which is just plain silly. I dont use the red **** on anything, just blue.
________
Aprilia TXR312M
