oem clip-on raising is possible on 06 636
ORIGINAL: Dragone#19
Portland,,, I have not looked at the OMRRA schedule since I do not ride that one anymore. But to stay on topic, do you have shims on the shock linkage to take out and drop the rear? I am not that familiar with the 6r
If the rear shock uses a shim, pull that and reset your preload since both front and rear sags will be altered due to the change. as mentioned, not sure that the 6r uses a shim.
ORIGINAL: sup_uni
that looks freaking awsome man i might have to try that next winter after i get a good review from you lol
and evil-
those links are really cool, but i think i'm gonna make a set. they will be lighter and all ss. hopefully i can just get the length right!?! just looking at photos(the links that go from stock, 1.25 and 2.5)... lets say the bolt is a ten mm... the holes are prob. 11mm on center. so i need to create a new link with a hole 5.5 mm longer/shorter than stock. haven't even taken a look to see if it would need to be longer or shorter.
heres links like i'm talking about--
http://i118.photobucket.com/albums/o...ock8/66102.jpg
yep, those are easy to make, if you have some extra stock laying around you can make a sweet template to go off of before you hit up the stainless. to bad your not in CA, i got a full fab shop right here.
Evil, you need to just start making them. All that lowering of the front & rear will cause a loss of ground clearance. Usually just a 5mm drop makes a BIG difference and .625 inches is HUGE!I was looking at a pair of CBR929/ 954 Clip-Ons and they look like they will work even being mounted below the triples but raise the bar height by a couple of inches.
ORIGINAL: speedracer138
i wish it was warmer here... i'd give it a test ride today. the other night i was out while it was below freezing. yea, not fun. when i downshifted with any guster at all, the *** end would come loose and weave back and forth. then i accidentally did my first rolling burnout... i was trying to do a (wussy) roll-on wheelie. i throttled up to about 6 or 7k, let off and hit it again... at first i thought the clutch wasn't grabbing. shortly thereafter i realized the rear was freespooling under me! Scary! moral of the story... it's scary to ride when it's 30 degrees out! sorry... totally off topic.
ORIGINAL: Ratkiller
Was there any issue of the clearance between your brake resivor and the windsheild fairing?
