Nitrous on zx6 how much is to much.
I gotta 94 zx6 and i have a stage 1 jet kit, a muzzy pipe, and a filter. I was going to get the sneaky pete kit, i was thinking a 20 maybe a 50 shot. The motor is stock with low miles, any suggestions?
i woud stay around a 20 shot to be on the safe side, also your bike is carb so you will need a wet kit, also wouldnt be a bad idea to go 1 step colder on the plugs and richen up the jets in the carbs so you want be lean when sprayin
Now another concern i have is spraying through shifts. On my old gtp i culdnt spray between 1st and 2nd because i could blow my input shaft. Will i see any troubles if i missed shift or if i just kept in on the juice through gears.
