Lowering
Old May 27, 2008 | 04:29 PM
tim121212's Avatar
Default Lowering
My friend bought an 08 Ninja 600. She is short. The dealership lowered it for her in the back but it looks like the front must still come down. Is there a way to do this? Can I move the forks? If so, how much?
Old May 27, 2008 | 05:32 PM
speedracer138's Avatar
Default RE: Lowering
You can go up to 10mm in the front maybe a little more. How much does she weigh? If she's light, you an back off on some spring preload front & back. Make sure to lower both ends the same to retain the handling. Also be careful that you don't lose too much cornering clearance.
Old May 27, 2008 | 08:03 PM
tim121212's Avatar
How much fork should be sticking out above the triple tree? I don't have access to another new 08 ninja anytime soon.
Old May 27, 2008 | 08:27 PM
How much did they lower the back and how did they lower it? Try 10mm in the front above the triple clamps.
Old May 31, 2008 | 04:47 AM
jcarm359's Avatar
you can slide the triple tree down the forks. make sure theyre exactly the same
kawiben
Jul 29, 2005 03:36 PM
ntence
May 28, 2005 04:52 PM
cyclops
May 23, 2005 07:54 AM
c10
Apr 27, 2005 01:31 AM
pinkninja
Apr 8, 2005 06:59 AM
