LIGHTS OUT
Old 03-14-2007, 07:50 AM
xmxracer's Avatar
Default LIGHTS OUT
MY NEW DUAL HEADLIGHT MOD LET ME DOWN TONIGHT. WHEN I PUT THEM ON BRIGHT IT SOUNDED LIKE IT POPPED A FUSE. HAS THIS HAPPENED TO ANYONE ELSE.
Old 03-14-2007, 02:15 PM
neoplanet's Avatar
Default RE: LIGHTS OUT
i would check to make sure the ground wire is still tight, if it is replace the fuse and see if it works again.
Old 03-14-2007, 03:32 PM
mikedrinfla's Avatar
aLSO MAKE SURE THE LIGHTS YOU ARE USING ARE NOT DRAWING TO MUCH..
Old 03-14-2007, 03:39 PM
Oh ya make sure there are no bare wires. Double check your connections and make sure they are all tight. Good luck let us know what you find out.
Old 03-14-2007, 09:05 PM
evil636's Avatar
Knee Dragging Pimp
no problems at all, def check the ground.
Old 03-14-2007, 09:38 PM
xmxracer's Avatar
THE FUSE WAS THE PROBLEM. I WENT FROM A 10 AMP TO A 15 AMP. SEEMS TO BE WORKING FINE. THANKS FOR THE HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 03-14-2007, 09:51 PM
evil636's Avatar
Knee Dragging Pimp
any idea why it popped the fuse ?
Old 03-15-2007, 12:11 AM
Notstock's Avatar
You should check if the fuse was supposed to be increased, if not you may be burning up some wiring soon and getting left stranded on the road.
evil, sweeeeeet bro
Old 03-15-2007, 12:30 AM
evil636's Avatar
Knee Dragging Pimp
you missed it again man. ill put the other pic back on sometime
Old 03-15-2007, 12:52 AM
xmxracer's Avatar
THE GUY THAT DID THE MOD FOR ME KIND OF EXPECTED THIS, BUT HE SAID THE INSTRUCTIONS DIDN'T SAY TO INCREASE THE AMPS ON THE FUSE. I'LL KEEP YOU POSTED ON HOW IT TURNS OUT.
Quick Reply: LIGHTS OUT
