how to do an OIL change?
Old Mar 15, 2006 | 05:22 AM
ryninger's Avatar
Default RE: how to do an OIL change?
I run it, check the level... Then go for an actual ride. I usualy change it right before I go on a trip of some sort...
Old Mar 15, 2006 | 05:31 AM
txredneckmedic's Avatar
oh ok.
Old Dec 13, 2006 | 03:45 AM
kazerotor's Avatar
Do you guys have any pics? i'm almost at 6000 miles and i'm going to do an oil change on my own. so any screenshots will be appreciated. do they have a haynes manual for a 2005 zx-6r?
Old Dec 13, 2006 | 07:19 PM
Remo's Avatar
kazerotor-- I have a service manual for our bikes, let me know if you are interested in one and I will send it to you
Old Dec 13, 2006 | 07:22 PM
Remo's Avatar
kazerotor--better yet, just give me your email addy and I'll give it to you
Old Dec 14, 2006 | 07:03 AM
speedracer138's Avatar
Notstock, why don't you fill the oil filter? I always fill in as much as I can without spilling so there's no bearing oil starvation (while the filter fills up) when you first start the bike up. I've always done this, even with cars.
Old Dec 14, 2006 | 08:37 PM
1991ZX600R's Avatar
I can't seem to find my where to fill my oil in my car, all I can see is a cap that says 710...[sm=joke.gif]
Old Dec 19, 2006 | 06:22 PM
Eklipse636's Avatar
im not the one to flame, but u guys are making this oil changing thing a little more complicated than it really is.... very very simple task. dont make it harder than it is. i dont think a haynes manual is necessary for this!
Old Dec 19, 2006 | 10:36 PM
1991ZX600R's Avatar
It's not exaclty second nature to everyone to care for their bikes. I think that if you want to learn things right, look in the book first or look at the factory specs so you don't get thrown off by people telling you it takes an hour to drain. It is a simple procedure, yes, but these are the ones that are the most important and often messed up because of over confidence and thinking that you do know everything there is to know about changing oil. I think this is an excellent post and gives you a few different perspectives on how people change their oil. Also, the manuals are a good reference for anything, what type of oil to use for the climate, what the factory used for oil/filter, how much it will use, even the torque used on the filter and drain plug! Props to the guys that use the manuals to reference even the most simple jobs on their bikes, at least I know the proper torque to put on my drain plug!
Old Dec 19, 2006 | 11:20 PM
On my 03, I have to remove the LH lower fairing only to change the oil. That's the first thingI do. Then loosen the drain bolt and let it drain while I loosen the filter and get all the rest of the stuff together. Speaking of oil change, It's time to do it again.
