hid help
Old Oct 21, 2008 | 11:32 PM
Sharky's Avatar
Default hid help
hey guys i have a 07 zx-6r and i want to know if there is a kit where i can have both hi/low on both sides now i know on the right side bulb is a h11 and the bulb on the left is a h9 if anyone has a link for a kit or or something that would be great or would i have to get just one hid low and hid high and now be able to have both hid hi/low.... thanks...
Old Oct 22, 2008 | 12:18 AM
OMalley912's Avatar
You can pm speedracer for the dual light kit, I believe he still has them. Best deal out there but can't remember how much and I haven't seen the ad on KF for awhile.
Old Oct 22, 2008 | 06:22 PM
sup_uni's Avatar
yeah speed is the way to go, only thing though his kits arent HID as far as i know, they just have the low/high with same bulbs
Old Oct 25, 2008 | 01:02 AM
Sharky's Avatar
could i buy the hid's separate and just fit them in the conversion kit?
Old Oct 27, 2008 | 07:11 PM
Sharky's Avatar
but then i wont have a high beam right?
Old Nov 21, 2008 | 04:21 AM
speedracer138's Avatar
On the 07-08 ZX6R's, the way they designed the headlights, it is very difficult if not impossible to do the Dual Headlight Mod that I do on the 03-06 636's. They have projector type headlight lenses and if you look carefully, you'll see the lower half on one side blocked and the upper half of the other side blocked. To do the mod, it would be necessary to separate the headlight housing from the lens and remove the blocked half with a dremel tool. The risk of melting the housing is not worth it for me to try.I melted a ZX10 headlight a while back so don't even want to mess with it. The best thing to do is run you high beams but adjust the high beam side down to the same level as the low beams so you don't blind oncoming drivers. Until someone devises a foolproof way to separate the headlights without deforming them, I'm not doing the 07-08's.
I'll have the 03-06 kits ready soon however.
proboarder093
Jul 22, 2008 06:58 AM
GS247
Jul 13, 2008 04:22 PM
ninja05
Mar 15, 2006 09:19 AM
NinjaBoy
Sep 27, 2005 12:51 PM
zxta6rr
Aug 2, 2005 09:47 PM
