HELP!! REMOVING FRONT/REAR SETS
Old Jun 24, 2007 | 08:15 PM
kwenui's Avatar
Default HELP!! REMOVING FRONT/REAR SETS
Having much trouble!!! here is where i am at:
what is next?!?!?!
Old Jun 24, 2007 | 08:22 PM
kwenui's Avatar
Default RE: HELP!! REMOVING FRONT/REAR SETS
also.. is the metal piece in the first pic allowed to be powder coated??
Old Jun 24, 2007 | 10:04 PM
shinobi636's Avatar
It looks like your OK, just disconnect the brake "actuator" master cylinder deal with the pin, and the rear set should come off. As far as powder coating, I really don't know what kind of heat the seals, and crap inside can take.
Old Jun 25, 2007 | 01:31 AM
kwenui's Avatar
ok! so i'm not unscrewing anyhting??? im just removing the pin from that hinge type thing??? because i wanted to get that powdercoated also... but i guess i can't get everything i want.. any tips on blacking out the master cylinder and the hinge??
Old Jun 25, 2007 | 02:12 AM
speedracer138's Avatar
Yeah, there is a cotter pin behind that pin; don't lose the little washer next to the cotter pin. You can just tape off everything and use some Hi-Temp gloss black paint (or whatever color)on the rear brake master cylinder.
Old Jun 25, 2007 | 03:42 AM
evor1's Avatar
you can just unscrew the entire rear set along with that hinge. the only thing sticking out of the master cylinder should be the threads of the bolt. just spin the rear set out like you would any other bolt
Old Jun 25, 2007 | 06:28 AM
evil636's Avatar
Knee Dragging Pimp
ORIGINAL: kwenui
testors gloss black model paint. if i have time and remember, ill get you a pic when i did mine, paints holding up great. and no you can not powder coat that part.
OMalley912
Feb 29, 2008 01:04 AM
biglg7
May 25, 2007 11:18 PM
biglg7
May 16, 2007 07:19 PM
056r
Apr 23, 2007 10:57 PM
05_ZX636
Oct 19, 2005 10:59 PM
