Help!!! part 2
Old Sep 1, 2009 | 10:10 PM
teamorange1's Avatar
Default Help!!! part 2
so i took everyones advise and did all the troubleshooting. i have a 2004 zx6r and it wont start. at first i checked the spark plugs and charged the battery.i keep getting no where. sometime it will boop and start for a few seconds but wont hold.after posting here you guys told me to troubleshoot some more. so i took everythin apart again. did a test for the fuel pump and its working. i did the spark plugs test against the heads and i get a spark. wireing is working fine. i am stumped. i even got a new battery on it. what can it be?
also i noticed after trying to start it a few times i get white smoke coming out the back i am guessing its fuel i dunno if that helps troubleshooting. also the spark plugs come out a bit wet .
thank you for your help!!!
Old Sep 2, 2009 | 01:21 AM
joe sprocket's Avatar
the same thing happened to my '98. i couldn't figure it out. i changed the plugs and good as new. also check your air filter just incase.
Old Sep 2, 2009 | 01:57 AM
change the plugs as mentioned
Old Sep 2, 2009 | 02:34 PM
old gas or fresh gas? gas wiil turn to varnish after a long time.
Old Sep 2, 2009 | 04:57 PM
no the gas is new its about 2 month old. the spark plugs are about 6 month old and i tested them and they have a spark. can it be like a down sensor?
Old Sep 2, 2009 | 07:44 PM
I don't know anything about these bikes. Do they have carbs with bowls? If so then get that gas out, by draining, and let in fresh, then try to start. If it doesn't have carbs, then never mind.
Old Sep 2, 2009 | 09:16 PM
no its fuel injected
Old Sep 2, 2009 | 11:17 PM
i was getting spark too, that's why it was hard for me to figure out. new plugs and whammo! all good.
Old Sep 2, 2009 | 11:25 PM
http://www.carlsalter.com/download.a...83046114097114 that is a manual for your bike. if the plugs don't do it. good luck
Old Sep 3, 2009 | 07:07 PM
thank you i will get new plugs and try it again. btw whats the best plugs to get? should i go for the e3 or dont even waste my money?
