Help with clutch/shifter
Old Oct 5, 2007 | 01:24 AM
05ZX6R's Avatar
Default RE: Help with clutch/shifter
Sounds like it's time for a new clutch. How many miles on the bike, stock clutch I presume...
Next time you do an oil change, go with a heavy weight oil like 20W40 or 20W50. It won't harm anything by using this heavier oil but you will notice it takes a little longer to get up to full operating temp and you may lose 1/4 hp or so.
Also don't ride too much in temps below 32 degrees Farenheit with the heavier oil, but that shouldn't be a problem now should it.
Old Oct 9, 2007 | 03:46 AM
hoehoho's Avatar
i had the second gear at around 10k rpm and it pops out to neutral - anyone thoughts?
Old Oct 9, 2007 | 05:01 AM
speedracer138's Avatar
Go to factorypro.com and see if they have a shifting star for your bike. Sound like you need to replace a couple of gears though.
Old Oct 10, 2007 | 03:18 PM
hoehoho's Avatar
I drained the motor oil - looks good and no metals - The only time the grinding happens is when from 1st to 2nd or 2nd to 3rd - so would this eliminate the shift fork from having problmes because it only happens on 2nd gear so bascially the i need a new 2nd gear?
Old Oct 10, 2007 | 03:34 PM
BlackNinjaZX6R's Avatar
somethin could be lose
norsseman
Apr 7, 2021 04:06 PM
Egon
KLR250
Feb 3, 2014 04:35 PM
lrkellogg
May 1, 2011 03:32 AM
jamieislimegreen
Ninja 500R
Mar 16, 2007 10:41 AM
wiesel 112
May 23, 2005 07:53 AM
