Help with clutch/shifter
Old Oct 2, 2007 | 01:11 PM
hoehoho's Avatar
Default Help with clutch/shifter
Hey guys - i have a big question. Recently I have noticed that whenever I slowly shift from First gear to Second gear - there would be grinding noise - also from 2nd to 3rd gear. But if i were to shift fast - no grinding noise. I have a 98 zx600e. The thing is that when i accidentally downshifted from 2nd to 1st - with the clutch still in - there was grinding noise too. Is this suppose to happen - cause I'm not sure downshifting from 2nd to 1st with the clutch still in would cause grinding noise - is my 2nd gear goign???? Thanks alot.
Old Oct 2, 2007 | 02:21 PM
rocketrotary's Avatar
Default RE: Help with clutch/shifter
Have you tried hitting it with a hammer?
Old Oct 2, 2007 | 02:58 PM
lets try that second[&:]how is the adjustment? with in tolerence?
ORIGINAL: rocketrotary
Old Oct 2, 2007 | 03:03 PM
sup_uni's Avatar
my 06 does this to i have been told by nemerous kawi techs that it is a normal kawi sound, differetn bikes have different quirks
Old Oct 3, 2007 | 01:48 AM
Check the adjustments as mentioned above.
Old Oct 3, 2007 | 02:45 AM
shinobi636's Avatar
I would check the adjustments for piece of mind, but Kawis have always had loud trannys.
Old Oct 3, 2007 | 05:28 AM
speedracer138's Avatar
Adjust your drive chain and if it doesn't improve, your 2nd gear could be going out and they aren't meshing/ engaging fully. Check you engine oil for metal fragments, dustor shavings.
Old Oct 4, 2007 | 01:27 AM
hoehoho's Avatar
hit my shifter with a hammer? - what would that do? - i do hear noises when the rpm is up at like 5000+ - i m not sure if the gear is grinding or loose metal.
Old Oct 4, 2007 | 04:03 AM
projectroc's Avatar
It would probably break it....I wouldn't try using a hammer. I'd leave that up to the dealers who know what they're doing.
Old Oct 4, 2007 | 07:11 PM
hoehoho's Avatar
i hear these like littel soudns around 5000 - like somethign rattling in the front whatever gear i m in when the rpm is over 5000? any help?
