Which Headlights?!?!?!
Old Feb 1, 2007 | 07:35 AM
Rains's Avatar
Default Which Headlights?!?!?!
Ok... so I am tired of my dull yellow bulbs... I remember having a great set of H4's on my '02 R6 and loved the way they lit up and reflected in the housing whenturned off... They were blue- and lit blue/white
What brand or wattage bulbs do you guys/gals use? or recommend?
Old Feb 1, 2007 | 08:06 AM
speedracer138's Avatar
Default RE: Which Headlights?!?!?!
Stick with the stock wattage or 65 watts. You don't want to run higher wattage that 120 watts combinedwith the Low & High beams both on or you'll start blowing fuses. Go with the Xenon filled blue bulbs. Check out my Headlight kits also, you may like them because you can have both side Low and High beams and I use the Xenon bulbs in the kits.
Old Feb 3, 2007 | 06:55 AM
GS247's Avatar
I have always known PIAA to be one of the best.
Someone posted a website on here a while back. i think it was called HID-lighting.com or something like that. I had the link but my comp crashed and i lost it. im sure someone here has it though. the website had HID kits for around $180. I would like to combine the HID kit with speeds dual headlight mod on mine eventualy.
Old Feb 3, 2007 | 07:13 AM
I can try and get Dual HID kits with Hi & Low Beams if there is enough interest.
Old Feb 3, 2007 | 07:55 AM
GS247's Avatar
http://www.fashtek.com/?gclid=COmugd...FTQkGAodfVlnnA
here is a kit for $139.
I am interested in the dual HID Hi & Low beams. i dont have the $$$$ right now. its all going in to my 74 GMC Jimmy. i dropping in a 383 stroker and the nickle and dime stuff is killing me. but after its in i will deffinetly be interested in that kit. Ill hit you up when the time comes though.
Old Feb 3, 2007 | 01:14 PM
nemo636's Avatar
2 PIAA Ultra whites, I run 'em, love 'em, and have had no problem!
Old Feb 3, 2007 | 04:07 PM
gotrice's Avatar
www.hardracing.com look up your year bike. I had these in my 05 636 and now in my buell. These are bright as hell and dont hurt your wiring or even pop a fuse. I had them in for over 7000 miles without any problems. And they are only $40
Tormentor636
Sep 24, 2006 11:11 PM
Knivez
Sep 2, 2006 06:57 AM
Hayate6
Aug 20, 2006 07:05 AM
NinjaBoy
Sep 27, 2005 12:51 PM
okstate815
May 9, 2005 02:09 AM
