gutting stock pipe
Old Apr 16, 2007 | 10:05 PM
aszrael1266's Avatar
The Dude
Default gutting stock pipe
I did a quick search and turned up some info on this. What i was wondering is, how loud will the pipe be if I remove the core from a stock 04 ZX-6r pipe? I got a rivet gun from a friend so i was going to drill out the rivets remove the core and re revit the pipe back together.
Old Apr 16, 2007 | 10:30 PM
evil636's Avatar
Knee Dragging Pimp
Default RE: gutting stock pipe
it will be obnoxiously loud and sound like ***. dont do it. unless you want to try it then i bet youll put the guts back in it.
Old Apr 17, 2007 | 01:29 AM
The Dude
I have never gutted a pipe before. If i were to gut it out. I thought that you can't put the stuff back in. So if i didn't like it i would need to get a new muffler right?
Old Apr 17, 2007 | 03:34 AM
speedracer138's Avatar
If you can install a perforated tube in it with some fiberglass insulation, you will have a good flowing pipe and decent sound also. If you remove everything the flow/ backpressure will be affected and you might lose power. Plus as said, it will be loud!
Old Apr 17, 2007 | 06:49 PM
evil636's Avatar
Knee Dragging Pimp
yep
Old Apr 17, 2007 | 07:38 PM
The Dude
Im not worried about lossing power the bike has more power then i need. At least for me any way. If its going to be too loud and sound like crap then I'll pass on it. I just wanted the bike to be louder so when im in traffic im less likely to get hit or merged into.
Old Apr 17, 2007 | 08:50 PM
evil636's Avatar
Knee Dragging Pimp
plus, youll need to re jet the carbs. its not worth the work in doing it. im not sure how the guts are on your pipe, but i remember needing a torch a grinder and some other stuff to get the junk out. all that and it sounded like a car muffler with holes in it. waste of time but fun chopping up someone elses crap.
Old Apr 17, 2007 | 08:56 PM
The Dude
My bike doesn't have carbs. If i were to get a slip on would i need a pc to retune the fuel injection or would the bike be ok with just a slip on and the stock air filter.
Old Apr 18, 2007 | 03:09 AM
Rains's Avatar
it messes it up a little - but not enough to worry. only when a filter is used in combination with the slip on is the re-tune needed.
Old Apr 18, 2007 | 08:34 PM
The Dude
any one got a sound clip or anything on how it sounds with the stock can gutted?
