Gas Overflow
Old Feb 4, 2010 | 01:06 AM
eztalking's Avatar
Default Gas Overflow
I have an 2005 636.
Does anyone know how the gas overflow works? I was told that there is a metal tube that runs from overflow hole on the top of the tank through the tank (gas surrounds the metal tube.) down to the bottom of the tank where the rubber overflow hose connects. Does anyone know if this is true?
My bike runs fine and there are no gas leaks when it is running. However, gas will run out of the overflow line when I fill the tank. It has happened multiple times and NO gas get onto the top ridge where the overflow is. It is a very steady drip. Someone said there is probably a small hole in the top of that metal line. When the gas is below the hole where is no problems. When I fill it and gas is above the hole it leaks.
I would think the only way to fix this would be with a new tank. Any idea where I can get a new tank? Has anyone heard of this?
Old Dec 10, 2021 | 10:34 PM
Owen636's Avatar
Default Aye there man ! Same issue .
Originally Posted by eztalking
I have an 2005 636.
Did you ever end up finding a good solution to the problem or did you just get a new tank man? I have the same exact issue right now with my 05 636 aswell.
durielk
May 30, 2013 10:41 PM
09klx
Jun 27, 2010 09:12 AM
eztalking
May 21, 2009 12:30 AM
k9jms
Feb 13, 2007 04:15 AM
Dragon
May 6, 2006 07:35 AM
