fron and rear tire
Old Apr 21, 2008 | 08:06 PM
mexsoy's Avatar
Default fron and rear tire
so I havea question
I’m going to go with the 120/70-ZR17
and on the rear is going to be 190/50-ZR17
had anyone try this set……. do I have clearance on the rear I read that on the front there is no clearance problem but I don’t know on the back
thanks in advance
Old Apr 21, 2008 | 11:31 PM
adramalech's Avatar
Default RE: fron and rear tire
well why are you changing the tire size for the rear tire anyways??? why not stay with a stock size???? the 2ct are recommended along with the pirelli and dunlop...it is usually your taste and feel of the tire...if you think that a bigger rear tire will help you out...it might just do the exact opposite!!! changing the geometry of the tires will change the overall geometry of the bike...
bottom line if you have to do this...then make sure your suspension is correct and make sure your not bottoming out...but yes i think you will have enough clearance...
Old Apr 22, 2008 | 02:14 AM
mexsoy's Avatar
Well I got this tires from a friend for good price they are diablos corsa so I still don't know if I'm going to put them on yet if I'm going to have to much trouble any other suggestions
Old Apr 22, 2008 | 09:02 PM
meanstrk's Avatar
Best bet would be to sell the 190 and put a proper 180 on it. That bigger tire is just going to screw up the handling anyways.
Old Apr 22, 2008 | 09:32 PM
mexsoy's Avatar
Well thanks
I think I'm just going with stock sizes then I'm sure I'll sell this ones later
wheel408
Ninja ZX-9R
Dec 4, 2010 02:48 AM
86gpz1000
Apr 17, 2010 05:06 PM
toyman1156
May 3, 2009 12:42 PM
fireroad
Jul 13, 2007 09:16 AM
kali_ninja500
Ninja 500R
14
Feb 10, 2007 02:13 AM
