Flushing Coolant on a 06 636
Old Oct 2, 2007 | 04:20 PM
NiteQwill's Avatar
Default RE: Flushing Coolant on a 06 636
ORIGINAL: meanstrk
ORIGINAL: NiteQwill
Umm... pull hoses?
All you have to do is remove 2 10mm bolts from the water pump and number 1 cylinder. Open the radiator cap, run a hose through there to flush all the remaining coolant. Lean the bike side-to-side to remove any remaining water. Refill, top off expansion tank.
Hmmmm. I was not aware that they had the drain bolts! Just as easy to pull one hose clamp though........
Pulling a hose clamp decreases the seal of your hoses. The hoses are meant to stay. Repeated pulling can only increase your chances of cracks, premature wear, and drying out. A $24 hose is much more expensive to pay for than a $.25 drain bolt. Not to mention, pulling a hose does NOT guarantee you have all the OLD fluid out.
To burp bubbles. Fill up your reserve tank and radiator up to the fill line. Start the bike. Squeeze and tap the hoses (be vigorous but don't break anything) until you stop seeing the bubbles come out of the radiator. Fill as necessary. Do not overfill the fill line. Stop bike. Replace cap. Add to reservoir. Start bike, allow the bike to warm up and the fan to kick in. Turn off, set for 30 minutes, check fluid level. Repeat as necessary.
Old Oct 3, 2007 | 03:40 PM
Ratkiller's Avatar
For furturereference.
2-52 PERIODIC MAINTENANCE
Maintenance Procedure
Coolant Change
WARNING
To avoid burns, do not remove the radiator cap or
try to change the coolant when the engine is still
hot. Wait until it cools down. Coolant on tires will
make them slippery and can cause an accident
and injury. Immediately wipe up or wash away any
coolant that spills on the frame, engine, or other
painted parts.
Since coolant is harmful to the human body, do not
use for drinking.
Remove:
Lower Fairings (see Lower Fairing Removal in the Frame
chapter)
Right Center Fairing (see Center Fairing Removal in the
Frame chapter)
Radiator Cap [A]
â—‹Remove the radiator cap in two steps. First turn the cap
counterclockwise to the first stop. Then push and turn it
further in the same direction and remove the cap.
Remove:
Left Center Fairing (see Center Fairing Removal in the
Frame chapter)
•Place a containers under the drain bolts [A] [B] of the water
pump cover and cylinder.
•Drain the coolant from the radiator and engine by removing
the drain bolts.
Remove:
Coolant Reserve Tank [A] (see Coolant Reserve Tank
Removal in the Cooling System chapter)
•Remove the cap [B] and pour the coolant into a container.
Install the coolant reserve tank (see Coolant Reserve
Tank Installation in the Cooling System chapter).
•Tighten the drain bolts with the washers.
â—‹Replace the drain bolt gasket with a new one if it is damaged.
Torque - Coolant Drain Bolt (Water Pump): 8.8 N·m (0.90
kgf·m, 78 in·lb)
Coolant Drain Bolt (Cylinder): 9.8 N·m (1.0 kgf·m,
87 in
[IMG]local://upfiles/1121/CC0BF37BE5CE42CE873E2992D311CB67.jpg[/IMG]
[IMG]local://upfiles/1121/D17D103545214ECE8AD31A1B3256301A.jpg[/IMG]
[IMG]local://upfiles/1121/F271EC8FC8A9480CAD68AC8909A9FC66.jpg[/IMG]
Old Oct 4, 2007 | 03:19 AM
Daves_636's Avatar
hey ratkiller, since you are in SD, maybe slip a little water wetter in there. we dont get the freezing temps and it does help with those east county rides when it heats up. dont forget to use distilled water and not tap. i am sure you already know this.
i had to change my fluid a few months back before track day. they dont like antifreeze in there on the track. if you plan to track your bike i would go ahead and just use water and water wetter. saves you the pain of having to do this again.
did you hear about the "rat" infestation at mission bay? hehe
Old Oct 4, 2007 | 03:11 PM
Ratkiller's Avatar
Good call Dave. Water Wetter is the hole reason for the flush. The bike was registering temps higher than normal, nothing to serious but I have over 6k on her so I thought is was time for a change anyway.
But yea I hear theratsescaped for a pharmaceutical company and are the size of a large dog.
407guy
Oct 10, 2023 01:42 AM
jrsings
May 6, 2010 03:03 AM
Derosian
Ninja 250R
Feb 6, 2008 09:20 PM
sickawi06
Sep 10, 2007 01:00 AM
