Flushing Coolant on a 06 636
Old Oct 1, 2007 | 05:50 PM
Ratkiller's Avatar
Default Flushing Coolant on a 06 636
How do you flush the coolant on an 06 636? And befor you ask YES, I did a search, the only thing I could find was for a EX500. https://www.kawasakiforums.com/m_169008/tm.htm
Most likely a couple of you have done this, do to the fact you have to replace the coolant for the race track, so any info wuold be appreciated.
http://store.58cycle.com/category_s/3018.htm
http://store.58cycle.com/category_s/3024.htm
Old Oct 1, 2007 | 07:32 PM
meanstrk's Avatar
Default RE: Flushing Coolant on a 06 636
What I do is pull a hose new the water pump and attach a hose. I flush the entire system after draining as much as I can and also let the bike warm up and flush a couple more times. After that it's time for the Water Wetter for the track!
Old Oct 1, 2007 | 08:21 PM
Ratkiller's Avatar
What do you mean by pull a hose and attach a hose? Which hose do you pull?
Old Oct 1, 2007 | 09:14 PM
meanstrk's Avatar
I usually pull of a coolant hose from the water pump and then use a garden hose and attach it to the coolant hose with a clamp.
Old Oct 1, 2007 | 10:07 PM
Ratkiller's Avatar
Cool,I get it. Usethe garden hose so it doesn't run all overthe place. So about how many flushesdoes it take to clear out the coolant?
Old Oct 1, 2007 | 10:32 PM
NiteQwill's Avatar
Umm... pull hoses?
All you have to do is remove 2 10mm bolts from the water pump and number 1 cylinder. Open the radiator cap, run a hose through there to flush all the remaining coolant. Lean the bike side-to-side to remove any remaining water. Refill, top off expansion tank.
Old Oct 2, 2007 | 06:25 AM
Daves_636's Avatar
dont forget to burp her...air bubbles arent good
Old Oct 2, 2007 | 07:15 AM
rocketrotary's Avatar
+1... they cause overheating problems.
Old Oct 2, 2007 | 10:05 AM
meanstrk's Avatar
ORIGINAL: NiteQwill
Umm... pull hoses?
Hmmmm. I was not aware that they had the drain bolts! Just as easy to pull one hose clamp though........
Old Oct 2, 2007 | 02:54 PM
Ratkiller's Avatar
So with removing the 2 - 10 mm bolts, the coolant will drain from the water pump? And whats the process of getting out the air bubbles?
