ECU mod and sprocket change
Old Jul 30, 2007 | 09:39 PM
mikeyntnc's Avatar
Default ECU mod and sprocket change
What effect would doing these two mods have ? Would one offset the gains of the other ?
Old Jul 31, 2007 | 12:37 AM
speedracer138's Avatar
Default RE: ECU mod and sprocket change
The ECU mod will give you top end and the sprocket change will give you the bottom end. Best of both worlds.
Old Jul 31, 2007 | 12:47 AM
mikeyntnc's Avatar
thanks speed , I'd really like to get just a bit more punch down low .The ECU mod is just an after thought in the event I may choose to do it at a later time .
Old Jul 31, 2007 | 02:19 AM
ORIGINAL: mikeyntnc
Mike, it'll take you 5 minutes to do the ECU jumper mod. Just use an aluminum or conductive wire /paper clip as the jumper. Bend it in a "U" and install it. You're done.
speedracer138
Jun 7, 2009 12:31 AM
speedracer138
Oct 6, 2007 10:32 PM
neoplanet
Jan 14, 2007 03:08 AM
dcorlando
Oct 4, 2006 06:40 PM
kaggriff
Apr 23, 2006 08:31 AM
