Does an 06/07 ZX10 front wheel fit an 05/06 ZX6R???
Old May 14, 2008 | 05:53 PM
gsims's Avatar
Default Does an 06/07 ZX10 front wheel fit an 05/06 ZX6R???
I found and affordable front from a 06/07 ZX10 - I have heard the front wheel for a 04/05 ZX10 is the same as for a 05/06 ZX6 (just different brake rotor thickness). Does anyone know if the 06/07 ZX10 is the same? I can swap an 06/07 front wheel onto my '05 ZX6???
Old May 16, 2008 | 05:25 AM
speedracer138's Avatar
Default RE: Does an 06/07 ZX10 front wheel fit an 05/06 ZX6R???
The 04-05 ZX10 Wheels aren't the same (may look the same) but have smaller diameter axles and bearings. The I.D. & O.D. of the wheel bearings are smaller than the ZX6R/ 636's. You may be able to make them work if you get the correct bearings but will need the ZX6R center spacer also. I don't know about the 06-07 ZX10 wheel bearing sizes or the offset of the rear wheel. Plus the rear is wider. 6.0 inch for the ZX10 vs 5.5 inch for the ZX6R.
Old Oct 9, 2014 | 05:02 PM
Kilo Stunts's Avatar
Do they make this bearing forsure or is this just a maybe?
Old Oct 9, 2014 | 05:04 PM
Do they have the correct bearing at the dealership or will I need to go to a beating supply store?
05kawi_guy
Feb 15, 2023 09:41 PM
Sid Post
Jan 27, 2009 01:46 PM
Kohburn
Jul 22, 2007 08:59 AM
dbdanny
Feb 7, 2007 09:12 PM
khck512
Sep 28, 2006 06:49 AM
