CR9EK
Old May 4, 2008 | 08:31 AM
fask's Avatar
Default CR9EK
CR9EK
what is the deal with this plug? Is it hotter or colder or the same?
What is the power gain on a stock engine?
Are the gains tried true and proven?
Why does it make more power?
Old May 4, 2008 | 02:18 PM
silverslug's Avatar
Default RE: CR9EK
Google. Go to the website. Then read the info.
Old May 9, 2008 | 02:22 AM
GS247's Avatar
Default RE: CR9EK
I did a google search and all i found was mixed reviews.
Old May 9, 2008 | 07:09 AM
suprakawigrl's Avatar
Default RE: CR9EK
C = 10 mm
R =Resistor Type
9 = Middle Heat Range (Range from 2 (hot)-11(cold))
E = Thread Reach 19 mm (3/4")
K = 2 Ground Electrodes
I am not sure what you are comparing the plug to but the info above came out of my NGK Book at the Shop...hope it helps.
Old May 9, 2008 | 11:39 PM
NMbottlecap's Avatar
Default RE: CR9EK
ORIGINAL: suprakawigrl
C = 10 mm
R =Resistor Type
I know which plugs goes to what car, by looking it up, but I always wanted to know what the numbers and letters meant. is there any way you could post up the "key" to understanding plugs? Thanks
Old May 10, 2008 | 04:47 AM
Default RE: CR9EK
i will try to get the legend up tomorrow.
Old May 11, 2008 | 06:05 AM
speedracer138's Avatar
Default RE: CR9EK
ORIGINAL: fask
CR9EK
http://www.mototuneusa.com/two_free_horsepower.htm
Old May 12, 2008 | 05:49 AM
Default RE: CR9EK
The numerical equivalent NGK part number for the CR9EK is 4548. Auto parts store will have it cheaper ($5.49 each) than bike shops ($10 + each).
Old Jun 3, 2008 | 02:44 PM
s197richie's Avatar
Default RE: CR9EK
As far as heat ranges go, domestic manufacturers = higher numbers are hotter (ex. autolite 25 is one range colder than 26) while import manufacturers are the opposite (ex ngk br8es is one hotter than br9es).
