2001 Speedo/Tac Replacement?
Old Feb 22, 2008 | 11:21 PM
Sidewinder33's Avatar
Default 2001 Speedo/Tac Replacement?
Hello everyone,
I was wondering if anyone had an idea if any other instrument clusters work on a 2001 ZX-6R. I'm not digging the dual analog sticks. I was just wondering if anyone knew if any other later models would work. I'm just worried about the connections working, I can make it fit if it works electronically. Thanks for the help.
Old Feb 26, 2008 | 10:38 PM
speedracer138's Avatar
Default RE: 2001 Speedo/Tac Replacement?
If the sensors work the same as on your bike, an 03-08 may work. You'll need an electronic cam sensor and speed sensor. The speed sensor on the 03-04 and 07-08work off the frontsprocket. The 05-06 ZX6R's work of the output gear and are not interchangeable with the other ones even though the plug is identical.
col0362
May 27, 2012 10:22 AM
Frankie Valentine
Apr 10, 2012 02:21 PM
eclipsehunter2001
Oct 26, 2006 12:24 AM
Green_05_636
Nov 12, 2005 06:47 AM
gotrice
Aug 8, 2005 06:18 AM
