120-70-17 Rather than 120-65-17
Old Nov 1, 2007 | 12:51 PM
Carmi990's Avatar
Default 120-70-17 Rather than 120-65-17
I have an 04 ZX-6R in desperate need of new tires and I want to try the Michelin 2CT and the front only comes in a 120-70-17 and my 04 takes a 120-65-17 the mechanic tells me it should work just fine and won't rub unless I do 140+.
Anyone already got a taller tire on there 03-04 bike that can vouch for this?
Let me know
Old Nov 1, 2007 | 02:08 PM
768 Ryda's Avatar
Default RE: 120-70-17 Rather than 120-65-17
120-70-17 will be fine bro, i ran a 120-70-17 on the front of my 04 zx6r without any problems at all, u have plenty of clearance under the front fender but i went back to a 120-65-17 bc of lowering affects
Old Nov 1, 2007 | 05:55 PM
speedracer138's Avatar
the 120/70 will be fine and won't rub at any speed. The only drawback is the taller 70 series will slow down the steering a little but on the 03-04 it will be okay because they are twitchy anyway.The 70 serieswill actually stabilize the bike at higher speeds.
Old Nov 1, 2007 | 11:11 PM
projectroc's Avatar
ORIGINAL: Carmi990
Let me know
Woah, tell your mechanic to put down the pipe... I personally don't want anything "rubbing" when I'm doing 140+ especially my front tire ! . My 70 series is just fine at all speeds.
Old Nov 2, 2007 | 01:55 AM
OMalley912's Avatar
Had the same problem buying a set of pp2ct for my 05 and didn't want to try a different series yet on the front. So just went with the pp / 65 so the front stayed a lil' lower.
Old Nov 2, 2007 | 02:07 AM
05ZX6R's Avatar
Specification--Sidewall--Radius---Diameter---Circumference---Revs/Mile---Difference
120/65-17______3.1in___11.6in____23.1in_______72.7in_____ _____872_________0.0%
120/70-17______3.3in___11.8in____23.6in_______74.2in_____ _____854_________2.0%
The 70 series tire will be a little taller which will sacrifice turn in angle
and effort needed to flip the bike from one side to the other but I doubt it
will be noticeable. The front suspension on my old bike was too stiff up front
and instead of changing the fork springs (no fork adjustments), I went with a
taller tire and it made quite a difference in the bump handling.
Old Nov 2, 2007 | 02:13 AM
OMalley912's Avatar
That's whatI meant to say.....right on 05!
Old Nov 2, 2007 | 01:17 PM
Carmi990's Avatar
Good Feedback.
Thanks
Old Nov 2, 2007 | 06:47 PM
mikedrinfla's Avatar
No problem I have the 2ct70 series on my 06 636 and have no problems with them at 170mph
Old Nov 29, 2007 | 12:27 AM
TORA's Avatar
The stock bridgstones are smaller outer diameter than the michelins 65 for 65 but,Hey the 70 works better for me than the 65 with the pilot power 05 636.
