06 636 City Lights
Old Nov 4, 2006 | 03:27 PM
dcorlando's Avatar
Default RE: 06 636 City Lights
ORIGINAL: MSR 05 6R
Thats good news I guess... I was going to do some LED lights in the corners of the headlight housing this winter when its to cold to ride. Ya, that does suck. Anyway, I was thinking about wiring them into my turnsignals though. Since there already there, my be not. If everything works out this winter, she should be a whole new bike for next season. Its going to be alot of work though...
Yeah, if you just get 2 standard relays and wire them into the turn signals, you can have them as running lights that blink off when the signal blinks on. Looks pretty cool I think.
Old Nov 6, 2006 | 12:05 AM
speedracer138's Avatar
You dont need any relays. Just wire them in. I'll try to post a write-up later when I get a chance.
Old Nov 6, 2006 | 04:40 AM
Remo's Avatar
so if we just wire them in they will be on and blink with the turn signals?
Old Nov 6, 2006 | 08:25 AM
Yes. one wire from each LED goes to the Power Brown wire with Silver Dots (in the harness bundle with about a dozen wires by the steering stem) and the other wire taps into each turn signal wire (green for the LH & grey for the RH). The lights will stay on and blink alternating when the turn signals are activated for each respective side.
Old Nov 7, 2006 | 05:05 AM
GS247's Avatar
Thanks Speed.
I have some more questions.
What is the best way to mount the lights them self?
Did you get just a LED and a gromet (similar to a standard car alarm LED) or something else.
I got a licence plate fastner at Autozone with a bright blue LED that shines out. Im not quite sure how i am going to mout it though.
Another kid in town has the same kit on his 636 and it looks good from the outside, but he said he just drilled a hole and JB welded the unit in place. I kind of wanted a cleaner install job than he did. what do you think?
Old Nov 7, 2006 | 07:23 AM
You can use auto type corner marker bulb holders from an auto parts store and drill holes to make them fit. Just be careful when drilling the holes; don't let the drill bit pull thru or you may damage the headlight lens. Use a cardboard tube as a stop. AutoZone has the best LED bulbs for $10 a pair. They are 168/194 replacements.
Old Feb 25, 2007 | 08:22 AM
636girl's Avatar
Hey Speedracer, is the 05 636 wiring harness the same as the 06 you guys are talking about here? I have been reading through the threads on moding my headlights to the dual beam and have been looking for more info on the running lights. sorry if I missed a thread somewhere but I think I have checked most of them. As well is this the most detailed thread on the running lights or is here anotherone I should look at?
I can hardly wait to have the dual light mod done and if my bike is ready for it i want to put the running lights in as well.
I am up in Canada so shipping wiring harnesses back and forth may be more hassel than its worth so I will have my mechanic do the mods for me here i think...
Old Feb 25, 2007 | 07:22 PM
mikedrinfla's Avatar
Well speed racer sells the dual headlight kit with the LED light for the corners. DIY KIT IS $75 AND $15 FOR THE LED MOD. Look on e-bay under dual headlight kit and you will find his e-bay ad the.
Old Feb 26, 2007 | 03:13 AM
NinjaNeal's Avatar
pics?
Old Feb 26, 2007 | 04:09 AM
What do you want pics of Ninjaneal?
