04 636 swingarm ??
Old Aug 2, 2007 | 09:29 PM
tracek180's Avatar
Default 04 636 swingarm ??
hello all, i just purchased an 04 636 about a month ago. it is my first bike. I know sportbikes are not built for comfort but i was wondering if there is a way to adjust the swingarm to cause a more relaxed or less agressive position on the sit. i am average build and height and find myself always jammed up against the tank. the more bikes i look at, it seems that the seat is almost flat or horizontal if you will and mine seems to slant a lot towards the front. any help would be great. thanks. and i have to say i have learned alot already on this website.
Old Aug 2, 2007 | 09:32 PM
mikeyntnc's Avatar
Default RE: 04 636 swingarm ??
shave the seat ??????????????
Old Aug 2, 2007 | 10:21 PM
768 Ryda's Avatar
have your seat modified to fit your needs
Old Aug 2, 2007 | 11:34 PM
tracek180's Avatar
its not the actual seat it the angle at which it is, which is due to the angle of the swingarm.
Old Aug 2, 2007 | 11:53 PM
aszrael1266's Avatar
The Dude
You can get a stomp grip it helps your theighs grip the tank. so you don't slide up. I got an 04 also and that tank is sharp enough to castrate your self if your not carefull. I learned the hard way never wax your gas tank.
Old Aug 2, 2007 | 11:55 PM
The Dude
On second thought It would probly be easyier to raise the triple clamps you wont be leaning forward on the bike as much if you do. But it will effect the handling by changing the geomtry of the bike.
Old Aug 3, 2007 | 12:49 AM
mikeyntnc's Avatar
yes but if you shave the seat and get angled backwards a little you shoudn;t slide forward as much . Just a thought .
Old Aug 3, 2007 | 04:29 AM
speedracer138's Avatar
Trust us, it's the angle of the seat. I have an 03 and shaving the seat solved the problem. If you adjust the swingarm, it will affect the handling. Go to the DIY section; here isthe write-up on how to shave the seat.
https://www.kawasakiforums.com/m_63779/tm.htm
I don't think I have slammed the boys in the tank since I did this mod. More comfortable too!
Old Aug 3, 2007 | 06:34 AM
evil636's Avatar
Knee Dragging Pimp
all hail the seat shaving mod and your junk will thank you.
Old Aug 3, 2007 | 12:07 PM
Pilky's Avatar
+1 on shaving the seat.
Its one of the best things i did.
