02 zx6r rebuild thread :)
Old May 14, 2008 | 02:21 PM
Default RE: 02 zx6r rebuild thread :)
looks good man! thanx for sharing, can't wait to see the final result.
Old May 17, 2008 | 01:16 AM
selfinfliction's Avatar
almost done
gonna start her up tomorrow morning, and put the chain on. may take it for a bit of a spin around the block if everything works out ok
Old May 17, 2008 | 02:23 AM
ynks4evr's Avatar
WOW that looks awesome. Im thininking of doing some polishing on my '02, id also appreciate a short write up cause ive found 20 different methods. I was thinking of stripping the parts then using sandpapper 400-2000 grit (palm sander for the first steps?) then using the three different colors of polish brown tripoli, red rouge, then white rouge (dremmel with a buffing wheel?). I think im gonna practice on something b4 i start takin parts of the bike.
Old May 17, 2008 | 02:33 AM
hold off before you start, cause i only use a 120-400 grit, going over that is useless (as long as you have the correct tools) because emery compound on a sisal wheel will remove alot of casting marks and emery is 400 grit. so it's doing the same thing over if you go up to 2000 grit, then use a compound that goes back to 400, know what i mean?
i'll try to get the write up done this weekend
Old May 17, 2008 | 02:37 AM
ynks4evr's Avatar
not a clue hahaa, i dont know much about this stuff, i dont have much specialty tools i was just going to make due using a palm sander, dremel, and elbow grease.
Old May 17, 2008 | 02:53 AM
you'll need a bench polisher for all the stuff you can pick up, and either about a $400 motor and flexshaft or a air powered die grinder with a speed control. then the consumables to do a single bike will cost about $50
Old May 17, 2008 | 03:19 AM
speedracer138's Avatar
Dude, you need to open a shop doing this stuff! You'll be RICH! You do awesome work!! Some of the best polishing I have ever seen! The bike looks great!
Old May 23, 2008 | 01:35 AM
just got the tank back, i must say that it's a damn good job... it is such a deep glossy black it looks plastic
Old May 23, 2008 | 04:29 PM
Okay okay. Hurry up and put it on the bike! Finish it so we can see the pictures of it all together! Can't wait.
Old May 23, 2008 | 11:10 PM
tada
