brake went out!
Old May 11, 2007 | 12:50 AM
vuskavich's Avatar
Default brake went out!
I have no back brakes.. i dont know what the F... happen. Theres fluid in the resivor, its just when i press the back brake nothing happens and theres no pressure to it. Also the light doesnt work for the back brake... any ideas on whats happening?? thanks
Old May 11, 2007 | 02:09 AM
Default RE: brake went out!
The light does not work either? You running the pressure type switch or the stock lever switch?
Old May 11, 2007 | 02:25 AM
lemac's Avatar
sounds like a bad cylinder... any leaks?
Old May 11, 2007 | 03:16 AM
Does not sound like leaks lemac. If there is fluid in the resevoir. Sounds like a good bleeding is in order and a change of fluid.
Old May 11, 2007 | 04:21 AM
vuskavich's Avatar
my dad usually does a lot of things for my bike when it breaks or whatever, but he now lives in a different state... how do you bleed bike brakes?????
Old May 13, 2007 | 03:51 AM
Mott Power's Avatar
did you drop your bike recently at all?
and check your pads
klx678
Nov 19, 2014 03:44 AM
deej
Nov 14, 2012 12:11 AM
Tdizzle
Apr 18, 2009 06:29 PM
ntloser
Oct 23, 2006 02:07 PM
evil636
Apr 22, 2006 11:52 AM
