2004 10R Clutch resolution needed
Old Sep 14, 2009 | 04:44 AM
razorback_02's Avatar
Default 2004 10R Clutch resolution needed
my clutch is starting to slip really bad. It catches really late. No acceleration now. anytime I get over 6000rpms at anything past 1/4 throttle it just zooms twards redline with no real acceleration. Is there anything I can do to adjust it or something cheap (<$20) I have oil on hand so I'm not worried about removing the engine cover. I just need to get it through the next couple weeks. A new clutch is in the budget later in the off season.
Old Oct 13, 2009 | 12:26 PM
fgk228's Avatar
if this helps, on the clutch leaver there is the cable running into it. remove the rubber cover and there should be a bolt or a washer or something that is threaded. turn one way see if it helps, if it doesnt turn it the other way. i cant remember what is exactly on this bike but every this should be fairly generic. there will be an adjustment on the clutch, 99.99% of all clutches have it, weather it is motorcycle, automotive or marine.
Old Oct 14, 2009 | 03:02 AM
definitely check your cable adjustment. Also not sure on how you are using the clutch, but on hard launches, the 10r is a toughy to launch nicely.
vuskavich
Ninja ZX-10R
Nov 18, 2007 08:35 PM
SickSuzuki311
Sep 10, 2007 03:58 AM
beansbaxter
Oct 9, 2006 11:33 AM
Dragone#19
Mar 7, 2006 06:37 AM
lemac
Jan 4, 2006 05:41 PM
