Speedo cable
Old Nov 1, 2007 | 05:43 AM
Blackhawk2k7's Avatar
Default Speedo cable
ok so every time i go to work or play around etc, and for some reason i get a wild hair you know where, and pop a wheelie, my speedo cable pops out of the thread on spot in the dash, ive fixed it by just barely screwing it back on, and let me tell you its a pain, so my question is should when i do my winter overhaul on it should i put blue (or any other color) lock-tite on the threads when the fairing is off? also where can i buy a lighter rim?
Old Nov 1, 2007 | 05:58 AM
calamarichris's Avatar
Default RE: Speedo cable
Yes. Any kind of threadlock will help hold that threaded barrel on. It's much easier to do a thorough job if you remove the front fairing assembly and clean everything well.
Are you sure you want a lighter rim if you're riding wheelies?
Peace!
-CCinC
Old Nov 2, 2007 | 01:39 PM
dragknee's Avatar
yeah locktite that puppy up. use the blue IMO. the red is pretty much "permanent" and probably isnt coming off without a torch and hammer. you dont wanna take a torch and hammer to the back of your gauges do you?
Old Nov 3, 2007 | 07:16 AM
hmm, if it happens so often, the threads on the plastic cluster may be toast by now?
Frankie Valentine
Apr 10, 2012 02:21 PM
CousinLarry
May 11, 2010 12:24 AM
lcpl0331
Aug 12, 2008 02:10 AM
joemeltn1
Jul 29, 2008 11:45 AM
eclipsehunter2001
Oct 26, 2006 12:24 AM
