numb feet
Old Jul 6, 2007 | 11:26 PM
GoFast908Z's Avatar
Default numb feet
as i've been going on longer and longer rides lately, i find that my heels start getting tingly/numb/painful after 30 min of riding (without shifting, ie freeway). What should i do to keep it from being uncomfortable. btw, i'm 5' 10" and 180lbs. I tried putting my feet up agains the passenger footpegs, and that helped a little. Is that a big no-no? I wouldn't take corners like that but it was more comfortable.
Old Jul 7, 2007 | 01:44 AM
Default RE: numb feet
What pegs are you running and with what gear ie boots?
Old Jul 7, 2007 | 03:51 AM
calamarichris's Avatar
I've ridden less comfortable bikes more than a thousand miles in less than 24 hours without getting numb feet.
I recommend learning how to relax in the riding position and perhaps trying other protective footgear.
Good luck and let us know how it goes.
Peace!
-CCinC
Old Jul 7, 2007 | 04:38 AM
yankee7568's Avatar
Also how old are you. That might be a part too.
Old Jul 7, 2007 | 08:34 AM
GoFast908Z's Avatar
its the stock footpegs. I've got some Alpinestar 1-0-1 shoes. I'm relaxed just fine, it just seems my feet get uncomfortable after a while.
Old Jul 7, 2007 | 06:38 PM
aszrael1266's Avatar
The Dude
My right hand goes numb but 636's have a good amount of vibrations in the bars. When I've got my oxstar boots on I do feel more vibratsions in the sole then I do when I wear steel toed boots. Doing 400+ miles in one day I havn't had any numb feet. Have you tried keeping the ***** of you feet on the pegs? I know when I'm on the freeway I just sit back rest on the tank and rest the ***** of my feet on the pegs. Also I would think the 500R would have less vibration then a 636 because of the ruber on the pegs. Then again it very well might be causing more vibration. You finish your break in yet?
Old Jul 7, 2007 | 06:44 PM
Notstock's Avatar
ORIGINAL: GoFast908Z
may its the boots.
Are they real tight?
Old Jul 7, 2007 | 06:57 PM
The Dude
What size shoe to you wear. I'm 9.5 my oxstars are size 10 if they fit you give them a try and see if you still get the numbness.
ORIGINAL: Notstock
may its the boots.
Old Jul 10, 2007 | 07:02 AM
GoFast908Z's Avatar
i tried putting the ***** of my feet on the pegs and that helped, although the position made my legs a little sore, but it was manageable.
Old Jul 10, 2007 | 12:19 PM
BurntOrange's Avatar
If the soles of those 1-0-1s are too soft, that could allow pressure from the pegs to cut blood circulation. You probably need boots with stiffer soles.
