need some help!!
Old May 26, 2007 | 09:23 PM
oldtruckluvr's Avatar
Default need some help!!
I have an 03 Ninja ex500. i want to integrate the turn signals into the brake light so i can eliminate the bulky signals. is there any way to get the signals to work with the rear light? does anyone know how to wire it so the regular light, brake light, and turn signals all work correctly. please help! i appreciate it. i dont want to buy a kit for $50.
Old May 27, 2007 | 01:40 AM
Default RE: need some help!!
hmm, being a truck lover, you should be able to use your meter to find that info.
Old May 27, 2007 | 03:56 AM
ok, so i figured it all out...actually bought a adapter kit. so everything works now, but just one more question, the turn signals work normal without the brake light, but when i use brake light and turn signal, the signals are blinking extremely fast. all the grounds are on the negative of the battery. is this normal, or can i get something to make it blink the same speed when the brake light is off? thanks
Old May 27, 2007 | 04:27 AM
ohms law bro. kind of curious on the adapter that you mentioned also.
Old May 27, 2007 | 04:33 AM
the reducer i got was from a local auto store, it is a tail light convertor that can be used on trailers and trucks... seems to work only issue is with turn signal and brake light...only cost me 8 bucks...is there some sort of power reducer for the ohms? what size resistor will work for it, and can i get it at a local auto store, or do i have to order it online? thanks
frrogger1
Mar 9, 2006 08:30 PM
Remo
Oct 14, 2005 04:13 AM
devestator_x
Aug 7, 2005 11:09 PM
ryffryda
Aug 7, 2005 07:45 PM
harryman
Jun 19, 2005 04:11 AM
