ex 500
Old Jul 9, 2008 | 02:31 AM
lake55124's Avatar
Default ex 500
is there a way to check and and fluid to the front shocks?
Old Jul 9, 2008 | 02:35 AM
Default RE: ex 500
Well first of all welcome to the forums, secondly introduce yourself in the new members area and third you could drain it all and put in the right amount to make sure, other than that I don't really know.
Old Jul 9, 2008 | 02:43 AM
lake55124's Avatar
Default RE: ex 500
JUST DRAIN IT FROM THE BOTTOM AND ADD AT THE TOP, WHAT FLUID WOULD YOU RECOMMEND
Old Jul 9, 2008 | 03:12 PM
calamarichris's Avatar
Default RE: ex 500
The 500's forks do not have drain bolts at the bottom. (Seems like the only bike to have these anymore are the KLR650.)
You have to remove and open the forks, pump the old oil out, replace it with new oil, pump the forks a few times, then carefully measure the distance from the top of the tubes.
It's not a simple thing like a motor oil change. I recommend getting a copy of the Factory Service Manual (which is different than the Owner's Manual) and supplement. This book will describe it in detail and even include picturesjust follow it like a cook book.
And finally, the fork oil doesn't have to be changed as frequently as motoroil. After changing out the cheap stock oil, I usually change mine every 20,000 miles.
Good luck and let us know how it goes.
-CCinC
Old Jul 9, 2008 | 06:42 PM
dragknee's Avatar
Default RE: ex 500
my 93 has drain bolts.
Old Jul 9, 2008 | 11:48 PM
lake55124's Avatar
Default RE: ex 500
no i do have drain holes, but if i drain it where do you fill it
Old Jul 10, 2008 | 03:05 PM
Default RE: ex 500
You have to remove the handlebars, press down the disc-caps at the top and pop out the $#&^% circlips, which is explained in detail in the Factory Service Manual, as I mentioned in my previous post.
cyclewizard
Jun 12, 2007 04:43 AM
HAHNBOYGA
Jun 2, 2005 03:33 AM
schmidtc
Feb 22, 2005 03:36 AM
ZX12Rider
Feb 10, 2005 03:00 PM
nixoid
Dec 28, 2004 11:14 PM
