Crankshaft Rebalance?
Old Jan 5, 2008 | 11:23 PM
bruno426's Avatar
Default Crankshaft Rebalance?
hey there guys. Bruno here.
Well I got the parts from arias in, and I was wanting to get a little input from you all.
I got the pistons in, and they are made from a lighter alloy, however, I do not know what the total weight was on the stock pistons. So my question is this, what is the weight in grams of the stock piston for a 1988 ex500. If the pistons are the same weight, then the only thing I need to do is have them matched. If they are different, then I need to have the crank rebalanced. Right? I am used to working on V engines where anytime you change a piston or rod design, then you change bobweight and need to rebalance, however I am not up on balancing a inline engine.
Any ideas guys. Also I got a new generator/flywheel and would like to know if this would make the crank system need to be rebalanced. Also, anyone know what a ballpark figure would be on rebalancing this system if it needs to be done.
thanks guys, Ill post pictures soon!!!
FredS
Apr 5, 2009 10:45 PM
WhipSaw
Ninja 500R
Nov 13, 2007 06:17 AM
marvbull
Ninja ZX-9R
Oct 9, 2007 08:56 PM
Dragone#19
Ninja ZX-10R
Dec 23, 2006 07:38 AM
dan52ohio
Jun 18, 2005 03:42 PM
